EPPENDORF - Microcentrifuge 5415 R
by EPPENDORF
Microcentrifuge 5415 R is an ideal workhorse for the lab. It features easy-to-use control knobs and a digital display of time and speed. Speed can be displayed in rpm or g-force, which saves you the time of performing tedious calculations and improves reproducibility. A separate, adjustable-speed Short Spin button provides easy, quick spins. The timer can be set to 99 minutes or continuous runs.
As the smallest and quietest refrigerated microcentrifuge on the market, Model 5415 R's compact cooling system and Fast Temp function quickly cools the chamber to 4°C (set temperature) in just 16 minutes. It can maintain 4°C, even at maximum speed—eliminating those countless trips to the cold room. Standby cooling also maintains chamber temperature when the centrifuge is not in use.
3Replies3 days ago | main board main board part numberReply |
4Repliesa year ago | Service manual for Eppendorf 5415R Anyone has this service manual? Need schematic to troubleshoot. Thanks.Reply |
0Replies6 years ago | eppendorf Centrifuge 5415R error 18 Hi,
Centrifuge turns on, but gives error messages 18. Instruction manual says "Temperature error. (? ≥ 5 °C). Switch off the centrifuge." the temperature is replaced by new sensor (pt1000)
can reset the Centrifuge with service keys?
chris Reply |
Height | 9 in |
Length | 17.7 in |
Weight | 46.7 lbs without rotor |
Width | 11.4 in |
