EPPENDORF - Centrifuge 5702
EPPENDORF Centrifuge 5702All 5702 models can be used in a range of settings, from the clinical lab to the cell culture lab. With various fixed-angle and swing-bucket rotors available, they can accommodate almost any kind of tube. With various fixed-angle and swing-bucket rotors and an extensive range of adapters, nearly all types of tubes can be used. Another advantage is that we have designed all rotors within the 5702 line to be interchangeable.
FORUMSView All (9)
1Reply8 months ago | Centrifuge Need services manual.Tks Equipment: EPPENDORF - Centrifuge 5702 Reply |
2Repliesa year ago | Looking for instructions to repair LCD display. Please help! My LCD displays gibberish. Otherwise the unit works well. I need the part #?Reply |
1Reply3 years ago | Main board part number I need the part number for the main board I have been on the phone with them for an hour then got the leaver your number and no one called back yet from Friday. Reply |
[list] [*] Large dials and an easy-to-read display [*] Switch between rpm and rcf [*] Speed can be set from 100 rpm to max. 4,400 rpm, in increments of 100 rpm [*] Separate Short Spin button [*] Timer can be set for up to 99 minutes [*] Continuous mode can be selected [*] Parameter locking [*] Super quiet [*] “At Set” function starts timer when set speed is reached for reproducible results [*] Glass window for quick calibration check [*] SOFT brake function for delicate samples. Optimized braking ramp for isolation of mononuclear blood cells using Ficoll density gradient centrifugation [/list]
Height | 9.5 in |
Length | 16 in |
Weight | 44 lbs |
Width | 12.5 in |
