EPPENDORF - Centrifuge 5702 R
by EPPENDORF
EPPENDORF Centrifuge 5702 R
All 5702 models can be used in a range of settings, from the clinical lab to the cell culture lab. With various fixed-angle and swing-bucket rotors available, they can accommodate almost any kind of tube.          This model has all the product characteristics that make refrigerated Eppendorf centrifuges so outstanding:          You can quickly reach the desired temperature by using the “Fast Temp” function. Likewise, standby refrigeration will maintain a particular temperature following use. Precise centrifugation is made possible through the “At Set rpm” function: time is counted down once the set rpm is reached; and as a result, different centrifugal runs can be more easily reproduced.          Another advantage is that we have designed all rotors within the 5702 line to be interchangeable.
FORUMSView All (4)
-SGL
3 months ago
cold temperature verification
how do you validate/calibrate the temperature on the 5702R?
Thanks
-SGL
3 months ago
Thanks
-SGL
3 months ago
Thanks
[list]    [*] Large dials and an easy-to-read display     [*] Switch between rpm and rcf     [*] Speed can be set from 100 rpm to max. 4,400 rpm, in increments of 100 rpm     [*] Separate Short Spin button     [*] Timer can be set for up to 99 minutes     [*] Continuous mode can be selected     [*] Two programming keys to store routine procedures     [*] Separate Fast Temp function     [*] Adjustable from –9°C to 40°C     [*] Standby refrigeration     [*] Silent running     [*] “At Set rpm” function     [*] Blue back-lit display     [*] SOFT brake function for delicate samples. Optimized braking ramp for isolation of mononuclear blood cells using Ficoll density gradient centrifugation.    [/list]
Height10.2 in
Length 22.8 in
Weight78 lbs
Width15 in
