EPPENDORF - Centrifuge 5804 / 5804 R
Unparalleled versatility.Featuring powerful, maintenance-free motors, these models accommodate a variety of rotors to meet your application needs. They are three centrifuges in one: a high-capacity, general-purpose centrifuge for cell harvesting; a high-speed centrifuge for separating cell lysates; and a microcentrifuge for DNA precipitations.
For lower capacity needs in one compact unit, Model 5804 and refrigerated Model 5804 R spin volumes from 0.2 ml to 4 x 100 ml at low-to-high speeds for a wide range of applications. These centrifuges can accommodate capacities of up to 16 x 15 ml conical (Falcon®) or 30 microcentrifuge tubes per run.
FORUMSView All (12)
0Replies2 years ago | Calibration of the Balance sensor. Anyone know where I might buy a service manual for the Eppendorf 5804 centrifuge. I need to calibrate the balance sensor. If not, does anyone have that procedure and is willing to email me a copy of it? I've encountered this problem after replacing the main board and Eppendorf is being quite uncooperative. Any help would be appreciated. Thanks! Dave Bryer Reply |
0Replies2 years ago | frequency converter can you please help me to get the schematic diagram of frequency Converter. Reply |
1Reply2 years ago | Dim Display Hi there, were having issues with our 5804R. The centrifuge works okay, but the LCD display has dimmed with time. At times it will come back but for the most part it is very dim/faint. Id imagine it is a loose connection or some broken part, perhaps even the LCD screen needs replacing. The instruction manual doesnt help much, and turning the instrument off and back on doesnt help either. Is there a detailed service manual out there? Something that can provide some guidance if I take the cover panels off and get into the body of the electronics. Let me know if you have any advice or guidanceReply |
- Interchangeable swingbucket and high-speed fixedangle rotors
- Spin up to 14,000 rpm, or 20,800 x g
- Low-profile 11.2 in/28 cm access height for easy sample loading
- Automatic rotor recognition senses rotor type to set maximum allowable speed—ensures safety
- Fast, simple programming of time, temperature (refrigerated models), speed/ g-force and radius value
- 34 user-defined programs
- Adjustable-speed Short Spin button
- Ten acceleration and braking rates
- Speed, g-force and radius correction values can be entered
- Values can be changed during centrifugation
- Temperature range from –9 °C to 40°C, with Fast Temp function for rapid cooling of the centrifuge chamber
- Standby cooling maintains temperature when not in use
- Speed can be set from 200 rpm to maximum speed in increments of 10 rpm
- Short Spin button
- Selectable program memory for up to 34 individual user programs
- Ten acceleration and deceleration rates for sensitive sample material
