EPPENDORF - Microcentrifuge 5415 D
EPPENDORF Microcentrifuge 5415 DCentrifugation and Eppendorf: The stuff that legends are made of. And one such legend in the making is the new Centrifuge 5415 D, the logical successor to the classic 5415 C, the unrivalled model of longevity and ease of use in laboratories, clinics and research institutes throughout the world.
The 5415 D has all the tried and tested technical features, including the almost indestructible maintenance-free drive. It goes without saying that the easy-to-follow digital display shows all significannt parameter settings at a glance.
The centrifuge can be operated using the same 24-position standard rotor for 1.5 ml and 2 ml tubes or with the 36-position special rotor for 0.5 ml tubes. With or without refrigexration - the right choice is always 5415!
FORUMSView All (6)
0Replies4 months ago | Schematic or service manual Can anyone share a schematic and/or service manual for the Eppendorf 5415D centrifuge? Thx, Bob Equipment: Eppendorf 5415D centrifuge Reply |
0Repliesa year ago | Eppendor 5415 documents? There are no documents listed under "Documents." There used to be - what happened to them?Reply |
2Replies2 years ago | main board main board replacementReply |
- Small and quiet
- Dials and a digital display
- rpm/rcf setting as required
- Separate short-spin key
- Max. rcf: 16,110 x g
- Maintenance-free drive
- Space-saving design
- 24-position standard rotor for 1.5/2.0 ml tubes (adapters available for 0.2 ml, 0.4 ml, 0.5 ml and 0.6 ml tubes); autoclavable; also available with an aerosol-tight lid
- 36-position special rotor for 0.5 ml tubes (adapters available for 0.2 ml tubes)
Height | 31 cm |
Length | 31 cm |
Weight | 8.5 kg |
Maximum Speed | 13200 rpm |
Width | 23 cm |
Acceleration time to max. speed: 13 s
Braking time from max. speed: 12 s
