Mindray - BS-120
by Mindray
BS-120 Auto Chemistry Analyzer
FORUMSView All (5)
-hany elhefney
a year ago
integration
how to integrate  or link to custom software
-Tymoteusz
6 years ago
Manual
Hi, Where can i find users manual? CheersReply
-Marika
8 years ago
Dilution
How do I set the automatic dilution?
For example if I want to make a dilution of 50 times.
[list]  [*] Up to 26 onboard chemistries and 4 ions         [*] Refrigerated reagent compartment         [*] Automatic probe cleaning, liquid level detection & collision protection         [*] Automatic dilution for abnormal sample         [*] External bar code reader         [*] Bi-directional LIS interface  [/list]
Height595 mm
Sample Capacity28 positions for reagents and 8 positions for samples in refrigerated compartment
Throughput100 samples/hr 300 with ISE
Wavelength Range340 to 670 nm
Length 570 mm
Power Requirements200-240 VAC
Weight75 kg
Light SourceHalogen-tungsten lamp
Sample Volume3 to 45.25 µL
Reagent Dispensing Volume180 to 450 µL
Width690 mm
[list]  Methodology: End-point, Fixed-time, Kinetic, optional ISE           Reagent/Sample probe: Liquid level detection, collision protection and inventory checking     Automatic sample dilution: pre-dilution and post-dilution dilution ratio up to 150  Cuvette: optical length 5mm            Absorption range: 0 ~3.5Abs (10mm conversion)           Calibration mode: linear (one point, two points and multi-points), Logit-Log 4P, Logit-Log 5P, spline, exponential, polynomial, parabola           Water consumption: 2.5L/hour De-ionized water  [/list]
