Aitecs - Syringe Pump SEP-10S
Cost-effective Syringe PumpThe AITECS SEP-10S is your right choice for cost effective intravenous, inta-arterial, epidural, or subcutaneous infusion of medications.
SEP-10S is designed for the accurate continuous infusion of medications. A wide range of syringe brands and sizes are accepted.
- Intuitive and user friendly operation.
- Simple entry of parameters via numeric keypad.
- Automatic and manual bolus modes.
- Set-Up menu enables customization of the pump
- Anti-bolus and anti-siphon functions increase patient safety.
- Titration allows to change the infusion parameters without interruption of infusion.
- All major syringe brands from 10 ml to 100 ml are accepted
- The drug library contains 15 drug names and can be updated by the physician.
Volume to be Infused | 0.1 to 9999 ml |
Height | 135 cm |
Length | 195 cm |
Flow Rate Range | 0.1 to 99.9 ml/h |
Weight | 2.6 kg |
Flow Accuracy | 1 % |
Infusion Pump Type | General-Purpose |
KVO Range | 0.1 to 10 ml/h |
Width | 305 cm |
