Aitecs - Syringe Pump SEP-10S Plus
by Aitecs
SEP-10S PLUS is designed for infusion via intravenous (IV), intra-arterial (IA), epidural, or subcutaneus routes of administration. It delivers solutions precisely and economically. Simple and fast entry of parameters via numerical keypad. Expanded range of available infusion rates.
[list] [*] Intuitive and user friendly operation. [*] Simple entry of parameters via numeric keypad. [*] Automatic and manual bolus modes. [*] Set-Up menu enables customization of the pump [*] Anti-bolus and anti-siphon functions increase patient safety. [*] Titration allows to change the infusion parameters without interruption of infusion. [*] All major syringe brands from 10 ml to 100 ml are accepted [*] The drug library contains 15 drug names and can be updated by the physician. [/list]
| Volume to be Infused | 0.1 to 99.9 ml |
| Height | 195 cm |
| Length | 135 cm |
| Flow Rate Range | 0.1 to 99.9 ml/h |
| Weight | 2.6 kg |
| Flow Accuracy | 1 % |
| Infusion Pump Type | General-Purpose |
| KVO Range | 0.1 to 10 ml/h |
| Width | 305 cm |
Power supply (220-230) VAC ± 10%, 50/60 Hz, or internal rechargeable battery Display type 16 characters x 2 line LCD with back-light
