Aitecs - Infusion Pump DF-12
General Ward Infusion PumpDF-12 can be used for continuous flow rate infusion of fluid drug and transfusion in ICU or CCU as well as infusion of anesthetic, anticancer agent or nutrient.
FORUMSView All (7)
0Replies3 years ago | i have problem in infusion the infusion gives alarm air what is problemReply |
0Replies3 years ago | Catalog aitec df-12 infusionpump User manual catalog aitec df -12 infusionpump Reply |
0Replies5 years ago | part no and price Drop sensor for infusion pum AITECS Model DF-12 part no and price Drop sensor for infusion pum AITECS Model DF-12Reply |
- Intuitive and user friendly operation.
- Wide range of flow rate settings.
- KVO system and tube-clamping mechanism increase patient safety.
- Improved drop sensor checks irregularities in drop count.
- Compatible with the most IV sets using a pre-programmed data.
- Titration allows to change the infusion parameters without interruption of infusion.
- Convenient 3-Level battery indicator displays the charging status and remaining capacity.
Volume to be Infused | 1 to 9999 ml |
Height | 125 cm |
Length | 166 cm |
Flow Rate Range | 0.1 to 99.9 ml/h |
Weight | 3.2 kg |
Flow Accuracy | 5 % |
Infusion Pump Type | General-Purpose |
KVO Range | 1 to 999 ml/h |
Width | 258 cm |
Display type: 7 segment (4 digit*2 line)
