Aitecs - SP-12S PRO Universal Syringe
by Aitecs
Universal Syringe Pumps
The SP-12S Pro offers the required maximum level of safety and flexibility for the precise delivery of medications within several patient care areas. The possibility to set 5 different profiles each up to 10 steps enables the use of preprogrammed drug protocols.
-Biomedical David
Wed Jun 14 2017
remedy to error 17
how to troubleshoot aitecs syringe pump and operate Aitecs-SP-12S PRO Universal SyringeReply
[list]  [*] Extended set up menu  [*] Pass word protected access to parameters  [*] Extended infusion rate range up to 1500 ml/h  [*] All major syringe brands from 5 ml to 100 ml are accepted  [*] The drug library contains 30 drug names and can be updated by the physician  [*] Possibilty to include drugs with profiled infusion  [*] RS232 interface for an automatic therapy data transfer to a central computer  [/list]
Volume to be Infused0.1 to 99.9 ml
Height135 cm
Length 305 cm
Flow Rate Range0.1 to 99.9 ml/h
Weight2.6 kg
Flow Accuracy1 %
KVO Range0.1 to 10 ml/h
Width195 cm
Patient weight 0.4 - 99.9 kg in 0.1 kg steps 100 - 200 kq in 1 kq steps    Display type 16 characters x 2 line LCD with back-liqht
