Aitecs - SEP-21S Plus double syringe
by Aitecs
The SEP-21S Plus ensures accurate volume delivery and consistent flow of infusuions via two independent channels in general wards and anesthesia departments.
0RepliesWed Feb 21 2024 | Aitecs - SEP-21S Plus ???? ?????? we need manual document to know errors of pump Reply |
[list] [*] Intuitive and user friendly operation achieved through dialog menu. [*] Extended maximum infusion rate up to 1500 ml/h. [*] The wide range of infusion rate units [*] Set-Up menu enables customization of the pump [*] Anti-bolus and anti-siphon functions increase patient safety. [*] Titration allows changing of parameters without interruption of infusion. [*] All major brand syringes from 5 ml to 100 ml are accepted. [*] Drug library contains 15 drug names and can be updated by the physician. [/list]
| Volume to be Infused | 0.1 to 99.9 ml |
| Height | 135 cm |
| Length | 306 cm |
| Flow Rate Range | 0.1 to 99.9 ml/h |
| Weight | 4.2 kg |
| Flow Accuracy | 1 % |
| Infusion Pump Type | General-Purpose |
| KVO Range | 0.1 to 10 ml/h |
| Width | 272 cm |
Patient weight 0.4 - 99.9 kg in 0.1 kg steps; 100 - 200 kq in 1 kq steps Display type 16 characters x 2 line LCD with back-liqht
