Aitecs - 2016 Syringe Pump
by Aitecs
Aitecs 2016 Syringe Pump
1Reply8 years ago | changing the infusion rate Is it possible to change infusion rate without stopping or pausing the infusion? Reply |
0Replies8 years ago | ask for Aitecs-2016 operator manual May I ask for Aitecs-2016 operator manual?Reply |
0Replies10 years ago | language ??? ???????? ?????? SP04? Reply |
[list] [*] Accepts syringes from 2/3 to 60 ml [*] Customized drug library (up to 300 drug labels) [*] Highly visible pump status indicator [*] Easy intuitive programming and operation [*] Improved alarm signals [*] Graphics LCD display [*] Rate range from 0.01 to 2200 ml/h [*] Advanced communication (USB, IrDA) [*] Line disconnection alarm [*] Rapid occlusion detection (ROD [/list]
| Volume to be Infused | 0.1 to 99.9 ml |
| Height | 120 cm |
| Length | 137 cm |
| Flow Rate Range | 0.01 to 99.99 ml/h |
| Weight | 2.3 kg |
| Flow Accuracy | 1 % |
| Infusion Pump Type | General-Purpose |
| KVO Range | 0.1 to 5 ml/h |
| Width | 320 cm |
