Ascor - Volumetic Infusion Pump AP 31P
by Ascor
Designed to meet the needs of modern I.V. therapy in ICU, CCU, anesthesia, surgery, cardiology and oncology.
1ReplySun Jan 08 2012 | power problem We have internal power supply problem on AP31P. Please advise how to open the unit. Reply |
[list] [*] extremely simple handling [*] wide range of infusion rate [*] easy modification of infusion parameters in running course [*] comprehensive system of audible and visual alarms & warnings [*] free-flow blocking device [*] long battery life [*] 3 modes of operation: flow rate, flow rate and volume, flow rate and time [/list]
| Volume to be Infused | 1 to 10000 ml |
| Height | 230 mm |
| Length | 230 mm |
| Flow Rate Range | 1 to 1000 ml/h |
| KVO Rate | 1 ml/h for flow rate 1 - 10 ml/h |
| Weight | 3.6 kg |
| Flow Accuracy | 5 % |
| Infusion Pump Type | General-Purpose |
| Width | 140 mm |
