Ascor - Single Syringe Pump AP14
by Ascor
Simple, safe & reliable
Designed to meet the needs of modern I.V. therapy in neonatal/pediatric/adult ICU, CCU, anesthesia, cardiology and oncology.
[list]   [*] User friendly software simplifies set-up and operation    [*] Large & easily readable LCD display    [*] Wide range of infusion rate    [*] Over 40 types of compatible syringes (10-60 ml)    [*] Drug dose calculation    [*] Automatic & manual bolus capability    [*] Automatic reduction of residual bolus after occlusion release    [*] Easy modification of infusion parameters in running course    [*] Comprehensive system of audible and visual alarms & warnings    [*] Drug library with user selectable drug names    [*] RS 232C interface    [*] Long battery life  [*] Data lock with a software-controlled passkey system    [*] Event log (up to 2000 events recorded in real time): on-screen display or as XML file    [*] 4 modes of operation: flow rate, flow rate and volume, flow rate and time, volume over time   [/list]
Volume to be Infused0.1 to 999 ml
Height180 mm
Length 140 mm
Flow Rate Range0.1 to 2000 ml/h
Flow Accuracy2 % complies with EN 60601-2-24
KVO Range0.1 to 5 ml/h
Width320 mm
