Ascor - Single Syringe Pump SEP11S
by Ascor
Simple, safe & reliable
Designed to meet the needs of modern I.V. therapy in neonatal/pediatric/adult ICU, CCU, anesthesia, cardiology and oncology.
[list]   [*] User friendly software simplifies set-up and operation    [*] Wide range of infusion rate    [*] Over 40 types of compatible syringes (10-60 ml)    [*] Drug dose calculation    [*] Automatic & manual bolus capability    [*] Easy modification of infusion parameters in running course    [*] Comprehensive system of audible and visual alarms & warnings    [*] Long battery life    [*] 4 modes of operation: flow rate, flow rate and volume, flow rate and time, volume over time   [/list]
Volume to be Infused0.1 to 1000 ml
Height140 mm
Length 170 mm
Flow Rate Range0.1 to 50 ml/h
Weight2.8 kg
Flow Accuracy2 %
KVO Range0.1 to 5 ml/h
Width310 mm
