Atom Medical - Infusion Pump S-1235
by Atom Medical
[b]Four sensor can check if the syringe is properly positioned on the unit.[/b] Any accidents possibly occured during infusion by improperly positioned syringe can be prevented by the feature. [b]Equiped with Lithium-ion-battery[/b] The battery enables the unit to keep in operation for Approx.3 hours and the replacement of the battery can be done easily without tools.
[list] [*] A numeric key pad is used to input the flow rate accurately and speedily. [*] A lithium-ion battery, which has no memory effect, is used in the unit. The battery capacity will not decrease even after repeated charging. [*] Operational errors are prevented by the messages urging the user to check for correct operation at the beginning of infusion or in priming. [*] Diprivan PFS 1%* is available. [/list]
| Height | 12 cm |
| Length | 12.5 cm |
| Weight | 2.1 kg |
| Infusion Pump Type | General-Purpose |
| Width | 32.5 cm |
