Philips - Page Writer TC50
EKG/ECG
A full line that fits the needs of any clinical environment PageWriter cardiographs are designed for the office through high volume hospital areas. Easy-to-use with an intuitive interface module and color coded ECG traces for signal quality. Superior workflow with report preview and automatic ECG transfer. Clinical excellence with Philips ECG algorithms which build on over 45 years of research and experience. High performance in a compact device. The Philips PageWriter TC50 cardiograph is an advanced, reliable, and compact ECG solution, that is easy to use to help you meet the demands you face every day and keep the focus on your patients.
FORUMSView All (4)
1Reply6 years ago | DICOM compatibility? Does anyone happen to know whether the TC50 is DICOM compatible/licensed to transmit data to a PACS system?Reply |
1Reply8 years ago | Philips TC50 Display Does anyone know where I can get a Philips TC50 ECG repaired other than the manuf? I believe the display itself needs replaced. The display "rolls" or "jitters" when it is rotated. I reset the display cable with no luck. Reply |
0Replies9 years ago | Add a Printer Can I add a wifi printer through the wireless LAN Card of the TC50? And if it, How can I do it? Reply |
- Easy to use- With the PageWriter TC50 cardiograph, each button lights in sequence, simply prompting you to take an ECG as easily as 1-2-3.
- Superb clinical decision support- Philips DXL 16-Lead ECG Algorithm provides industry-leading ECG interpretations and a suite of advanced STEMI diagnostic aids, including: Critical Values, ST Maps, and culprit artery identification.
EKG/ECG Type | Rest |
Image Display | 10 in Touch Screen |
