Mindray - BS-200
by Mindray
It’s tailored for small laboratories (used as a main instrument); medium and big laboratories (used as a back-up instrument)
1ReplyTue Feb 18 2025 | Mindray BS 200 Hello Mydray BS 200 is giving me a error 200680090002 only when is testing bilirubin total. I already repleace probe and syringe and that did not help. Did someone had problem like this? Equipment: Mindray BS 200 Reply |
4RepliesMon Sep 06 2021 | My LIS don't receive results from BS200 Analyzer when I clicked send!!?? I have developed an App that connects my LIS to analyzer Mindray BS-200 using hl7 protocol via TCP. It connected well but the results are not received!!! The analyzer and start Connect successfully but I still cannot transfer the result from our application (The Send button is enabled but we don't receive any HL7 message) would you please advise me of what I've done wrong!!!Reply |
0RepliesTue Aug 10 2021 | startup failure bs200 failing start up presenting with errors ;400000580008 and 30064120007.i have tried to check possible connection problems all seems well,and one notable thing is that when i send commands from the application software,for example move sample prove to wash well,the instrument do respond,if i command it to perform handshake,it gives the error 30064120007 and write main unit time out or no response. now in need assistance,what can i do or check,or what may be the problem.Reply |
[list] [*] 200 tests per hour, up to 330 tests per hour with ISE [*] Up to 40 positions for samples and reagents respectively [*] Automatic probe cleaning, liquid level detection, collision protection [*] 8 wavelengths [*] Refrigerated reagent compartment [*] Bi-directional LIS interface [/list]
| Wavelength Range | 340 to 670 nm |
