Mindray - DP-3300
by Mindray
With advanced digital beam-forming (DBF) technology, DP-3300 has realized significant improvement on image quality.
Meanwhile, broadband and multi-frequency transducers enable a wider range of clinical applications. Also, 128-frame CINE loop, 16-frame images storage and the second optional transducer connector provide operators with more options and flexibility. With such powerful features and ergonomic design, DP-3300 is the ideal model for users who seek for an economical product.
FORUMSView All (14)
-Dr Billo
3 days ago
How to set date and time
I have a Mindray DP 3300 that has lost time and date please assist me how to reset
-MICHALITSA
10 months ago
change the name of the previous doctor on the screen
Hi
"I recently purchased a used DP-3300, and I noticed that the name of the previous doctor still appears on the upper left corner of the screen. I'd like to change this name to mine. Could you please provide instructions on how to do this, or should I contact the manufacturer for guidance?"
thank you
-Ikmawanda
3 years ago
Repair failure
I have an ultrasound scan mindray Digi prince 3300 with a fault I tried to repair it but when ever I switch it on power fails to reach the monitor what should I do , I tried to put a capacitor on its power board it worked for just minutes and it was destroyedReply
  • Multi-purpose: abdominal, urology, GYN, OB, small parts, and orthopedics
  • Digital beam-former
  • Two transducer connectors (optional)
  • Multi-language function with English, French, German, Italian, Russian, Portuguese, Spanish and Chinese
  • Two USB ports
  • Multi-frequency transducer series
  • Max frequency up to 10MHz
Height385 mm
Length 306 mm
Weight10 kg
Clinical ApplicationsColorectal
Portable1
Image Display10 in non interfaced
Imaging ModeB, B/B, B/M, M
Width270 mm
