Nuve - NF 800/800R
Multi-purpose bench-top centrifugesFORUMSView All (8)
1Reply7 months ago | Centrifuge Instruction manual Equipment: NF 800R Reply |
4Replies3 years ago | E OFF The display show E OFF and StopReply |
2Replies3 years ago | Isue About NF800R I have a problem with Nuve NF 800/800R centrifuge. It displays Err#2 when start is pressed. Reply |
[list] [*] Programmable microprocessor control system [*] Programmable parameters: Program no., speed, time, acceleration and rates [*] Display of relative centrifugal force (RCF) [*] Four digital displays for programmable parameters [*] 1-99 minutes timer with hold position [*] Ten program memories [*] Stainless steel chamber [*] Safety features: Steel barrier ring, electronic imbalance detection, lid interlock, motor over temperature protection, rotor over speed protection [*] Wide range of accessories to accommodate most manufacturers' tubes and microtitre palte [*] Transparent hermetically sealing caps for the buckets of swing-out rotor [*] Powerful, quiet and maintenance-free induction motor [*] Minimum temperature increase in the chamber by means of ventilation system [*] Temperature control between -9°C / +40°C for NF 800R [*] Totally CFC free refrigerant fluid and insulation material for NF 800R [/list]
Height | 500 mm |
Length | 520 mm |
Orientation | Benchtop |
Weight | 52 kg |
Width | 590 mm |
[list] Speed Control Accuracy: ±20 rpm Acceleration/Braking Rates: 5/5 Maximum Power: 500 W / 800 W [/list]
