Nuve - NF 1200/1200R
Multi-purpose bench-top centrifugesFORUMSView All (4)
3Repliesa year ago | Troubleshooting My Nuve NF1200R is indicating Err with a red light indicator. This not balancing, how can I go by it. Eng. Peter |
0Repliesa year ago | Service manual The centrifuge is not balancing Equipment: NF1200R Reply |
1Reply3 years ago | Switch on When switching the Nuve NF1200 centrifuge on, how many bleeps are normal for the annunciation. This is not mentioned in the operators manual but surely has significance? Reply |
[list] [*] Programmable microprocessor control system. [*] Programmable parameters: Program no., speed, time, acceleration and breaking rates and temperature for NF 1200R. [*] Four digital displays for programmable parameters. [*] Display of relative centrifugal force(RCF). [*] 1-99 minutes timer with hold position. [*] Ten program memories. [*] Stainless steel chamber. [*] Wide range of accessories to accommodate most manufacturers’ tubes and microtitre plate. [*] Powerful, quite, maintenance-free induction motor. [*] Minimum temperature increase in the chamber by means of ventilation system for NF 1200. [*] Temperature control between -9°C / +40°C for NF 1200R. [*] Totally CFC free refrigerant fluid and insulation material for NF 1200R. [/list]
Height | 500 mm |
Length | 520 mm |
Orientation | Benchtop |
Weight | 47 lbs |
Width | 590 mm |
[list] No. of Program Memories: 10 Acceleration/Braking Rates: 5/5 Maximum Power: 500W / 800W [/list]
