Awareness Technology - ChemWell 2910
by Awareness Technology
ChemWell 2910 is a fully automated analyzer capable of running both EIAs and general chemistries in standard microwells.
ChemWell is a completely open system that is easy to program. Set up assays, routine jobs, quality control, panels, and even index calculations to suit your laboratory. With a completely open system you can program additional wash volume, increase the number of washes, or even direct the probe to pick up and dispense a probe cleaning solution after each specimen. And it is entirely password protected.              Precise pipetting of low volume specimens, elimination of carryover, and careful control of temperature are all essential for reliable results. ChemWell 2910 can make pre-dilutions, however, this is often not necessary since a high level of precision is achieved even with a 2uL sample. ChemWell 2910 can process EIA at ambient temperature or 37°C. An incubator is provided for biochemistry wells to provide precise kinetic reactions. The probe is also temperature controlled to deliver 37°C reagents.              RCA - Reagent Cooling Accessory now available for ChemWell®. Protects reagents from ambient heat. The removable racks can be refrigerated, pre-loaded, and ready for the next use.              ChemWell is designed to maximize dependability, versatility, and economy.       ChemWell uses standard, off-the-shelf microwells for all reactions. Performing biochemistry assays in microwells offers many advantages such as increased throughput and decreased cost per test. Uncoated microwells make low volume sample cups for biochemistry. They can also be washed for re-use. ChemWell 2910 reads vertically using 4 optical channels and 8 wavelengths.
-kuttyaxis
Mon May 06 2013
chemwell 2910 .chemistry not well
We are facing a lot of difficulties in bio chemistry in chemwell 2910. It's not working properley. The chemistry quality control are not fine with this mschine. using diasys chemistry kits and diasya calibratotor and controls.
-rekha
Wed Jan 18 2012
iq,pq,oq request for chewell 2910
i REQUIRE THE IQ,OQ & PQ of Chemwell 2910.
[list]    [*] 200 tests per hour        [*] No carry-over        [*] Liquid sensing probe tip     [*] 8-well wash head        [*] Level-sensing wash, rinse, and waste bottles        [*] LIS, STAT        [*] QC tracking        [*] Self-monitoring mechanics and optics        [*] Auto dilute and retest for over-range samples    [*] No custom disposables required        [*] IAD filters        [*] Creates automatic service reports        [*] Edit standard curves    [/list]
Reaction Volume: <250uL
