Awareness Technology - Stat Fax 4500
The 4500 is a compact, economical, standalone chemistry analyzer.Its streamlined design offers touch screen interface, superb optics, on-board curve-fitting software, and built-in printer to meet the requirements of modern laboratories.
FORUMSView All (17)
0Replies3 years ago | Filter Voltage- Low [3f] [3f, 3f, 6] What to if the filter voltage is low? Reply |
0Replies3 years ago | Need Firmware update for Stat Fax 4500 I need to update my Stat Fax 4500 Reply |
0Replies4 years ago | statfax 4500 cannot store? When running a test, the machine cannot store the standard curve. For example, when I run creatinine test,I accept the standard given and then I exit. Then I again open the run test option and run Creatinine again but it needs to run standard again and did not store the first standard I already run. What could be the problem w/ the machine? the costumers are complaining of the standard easily used up.Reply |
[list] [*] Accommodates 12mm tubes or cuvettes. [*] Interactive touch-screen LCD with USB mouse option. [*] Bichromatic optics. Standard model includes six filters - 340, 405, 505, 545, 580, and 630nm. Alternate filters available from 340nm - 700nm. [*] On board curve fitting calculations with step-by-step user prompting. [*] Single point calibration by standard or factor, multipoint calibration,kinetic rate by standard or factor (batch or singly). [*] NRTL and CE mark. [*] Stat Fax® readers use IAD filters. [/list]
