Awareness Technology - Stat Fax 3300
AWARENESS TECHNOLOGY Stat Fax 3300FORUMSView All (12)
0Replies6 years ago | Require EPROM Program of statfax3300 Dear All does anyone have program of 3300? If so can u share with me at srnsundarr@gmail.comReply |
1Reply7 years ago | Testing for calcium using a semi automated stat fax 3300 I have a semi automated stat fax 3300, and would like to test for calcium, I m wondering if standard wavelength needed 650 is available. Thanks for your help. Reply |
1Reply8 years ago | service manual for stafax 3300 We need service manual for statfax3300 Reply |
- Flip-up display screen.
- Large 240 x 128 pixel graphical display.
- Plug in standard external keyboard for easier data entry (sold separately).
- Use 40-column on-board thermal printer, external printer, or PC.
- Create a work list, run tests, print patient reports. Stores patient data.
- Shows kinetic plots in real time.
- Stores control values and creates Levey-Jennings plots for QC.
- Optical system is temperature controlled to 37C.
- Bichromatic w/ 6 filters and spaces for 2 optional filters (340-700nm).
- Adapts to use 12 mm round tubes, 1 cm square cuvettes, or built in flow cell.
- Vacuum system speeds sampling and reduces carryover.
- Calibration traceable to NIST standard.
- Stat Fax readers use IAD filters.
