Welch Allyn - CP 100
by Welch Allyn
A reliable, easy-to-use, and cost-effective ECG device for almost any office setting
0Replies3 years ago | i need lead snaps i need to purchase lead snaps Equipment: Welch Allyn - CP 100 Reply |
0Replies4 years ago | service manual how can we connect the universal ECG lead to this CP100 ECG machine of welch allyn as it is having 9 pin connector Reply |
1Reply4 years ago | Machine can't start Battery charging light not on and battery will not charge. How to check if transformer is working?? Battery is new. Screen flashes whiteReply |
[list] [*] A 12-lead resting ECG that provides accurate measurements [*] Optional MEANS ECG interpretation software for a second opinion [*] High-resolution thermal printer generates full-sized standard and customized reports [*] Lead quality graphic saves valuable time by highlighting poor connections [*] Full alphanumeric keyboard and LCD screen for easy patient data entry [/list]
EKG/ECG Type | Rest |
Weight | 11.6 lbs |
Dimensions: 15.6 in (39.7 cm) X 6.2 in (15.7 cm) X 16.2 in (41.1 cm) Keyboard type: Elastomer keypad with complete alphanumeric keys Paper type: 8.25 x 11 inches (21 x 28 cm), Z-fold thermal paper, 200 sheets Thermal printer (internal): Computer-controlled dot array, 8 dots/mm Thermal paper speeds 10, 25, 50 mm/s
