Welch Allyn - CP 200
by Welch Allyn
Welch Allyn CP 200™ Electrocardiograph with Optional Spirometry An easy-to-use, full-featured device with advanced options to help streamline office workflow.
0RepliesThu Jul 11 2019 | Mainboard CP200 faulty I have two CP 200 that have mainboard faulty. After swap with another mainboard from normal operated ECG machine, the malfunction unit works like new. When check the SMD fuse (F1,F2,F3) it still have continuity and works fine. The power supply board gives constant 12Vdc when connect to the mainboard. But the capacitors nearby the power supply connector doesnt have any charged voltage inside the component. Is there any idea on how to troubleshoot the mainboard of CP 200?Reply |
2RepliesThu Jun 01 2017 | software upgrade 2.6 Does anyone have the software to up grade the CP 200 and CP 100 to the 2.6 version so I can install the Li-Ion battery?Reply |
2RepliesSat Sep 03 2016 | Power on does 3 beeps and then displays a rainbow. It has a working battery. Reply |
[list] [*] A 12-lead resting ECG that provides accurate measurements Optional MEANS ECG interpretation software for a second opinion [*] High-resolution thermal printer generates full-sized standard and customized reports [*] Lead quality graphic saves valuable time by highlighting poor connections [*] Full alphanumeric keyboard and LCD screen for easy patient data entry [*] Large color LCD screen allows you to easily preview critical information on screen [*] Save time by using dedicated function or “hot keys” to perform the most common functions without scrolling through menus [*] Store up to 50 ECGs and 50 spirometry tests for later review and editing of patient data and interpretation [*] Easily connect directly to Welch Allyn CardioPerfect™ Workstation Software through cable interface [*] Optional spirometry testing and optional MEANS interpretation software [/list]
| EKG/ECG Type | Rest |
Flow transducer: 2.4 x 2.4 x 2 in. (6 x 6 x 5 cm) 0.4 oz (12 g) Pressure tubing: 2.2 yd (2 m) 0.9 oz (25 g) Sensor: 2.2 x 1.4 x 0.6 in. (5.4 x 3.4 x 1.6 cm) 0.9 oz (25 g) Tests: FVC, SVC, pre- and post-bronchodilator
