Beckman Coulter - UniCel DxC 600 Synchron
More Performance. More Simplicity. More Capacity.UniCel DxC systems are built to deliver maximum productivity for your laboratory. The systems have the capacity to help your lab thrive in todays environment. Plus, designed to minimize workflow interruptions and maximize user-friendliness, the UniCel DxC systems deliver a faster, reliable turnaround time.
FORUMSView All (3)
0Replies5 years ago | Barcode chemistry cartridge somebody knows the meaning of chemistry cartridge barcode? i want to create it to put it into UDR chemistry cartridge. for example if a read a TBIL barcode appears something like this: O6-0DZB2AW greetingReply |
1Reply5 years ago | LIS Com What Com to use? P0, 1,2,3????Reply |
1Reply13 years ago | qc lot conversion Is there any worksheet to plug in the values in order to get new lot correlation?Reply |
- For labs with lower volumes (approx. 100 – 500 chemistry samples per day) the UniCel DxC 600 delivers up to 990 tests per hour
- Delivers the results for 90 basic metabolic panels in an hour (NA, K, CL, CO2, CALC, GLU, BUN, CRE)
- Samples can be loaded continuously
- Add the closed-tube sampling (CTS) option to enhance productivity and safety
- Reduce the potential for worker injury by eliminating the de-capping step for most tubes. Workers have less exposure to repetitive motion injuries and less exposure to biohazards
- Reduce the potential for errors caused by evaporation or contamination
- Reduce time spent on tedious manual tasks
- Choose from a menu that includes more than 100 liquid, ready-to-use reagents
- The DxC 600 offers 65 different reagents on board at once
- Liquid reagents eliminate time-consuming reagent preparation
- Most reagents are packaged with enough volume for hundreds of tests, minimizing operator intervention with the system
- If reagents are required, operators can load while the system is running
- No need to interrupt workflow to reconfigure on-board menu
- Calibration processes minimize time-consuming, labor-intensive steps
- Calibration data is provided on disk, so technologists don’t have to key in necessary information
- Almost all calibrators are liquid and ready-to-use, eliminating reconstitution, clean up, and potential result variability
- The systems automatically accept within-range calibrations
- The systems require no daily maintenance and minimal weekly maintenance
- Automated routines for some maintenance procedures eliminate hands-on time by operators
- Proactive alerts for system maintenance let users know in advance when maintenance is due
- Onboard maintenance logs with supervisor approval facilitate paperless maintenance records
