Advertisement
Beckman Coulter - UniCel DxC 800 Synchron
Manufactured by Beckman Coulter
More Performance. More Simplicity. More Capacity. UniCel DxC systems are built to deliver maximum productivity for your laboratory.
UniCel DxC systems are built to deliver maximum productivity for your laboratory. The systems have the capacity to help your lab thrive in today’s environment. Plus, designed to minimize workflow interruptions and maximize ‘user-friendliness’, the UniCel DxC systems deliver a faster, reliable turnaround time.
QUESTIONS & ANSWERSView All
Be the first to ask a question about this equipment
PREVENTIVE MAINTENANCEView All
Be the first to submit a preventive maintenance post about this equipment
    Achieving Peak Performance
  1. Ideal for labs that process more than 500 samples per day, the UniCel DxC 800 processes up to 1,440 tests per hour
  2. Delivers the results for 90 comprehensive metabolic panels in just one hour (NA, K, Cl, CO2, CALC, GLUC, BUN, CRE, TP, ALB, ALP, AST, ALT, TBIL)
  3. Samples can be loaded continuously
  4. Add the closed-tube sampling (CTS) option to enhance productivity and safety
  5. Reduce the potential for worker injury by eliminating the de-capping step for most tubes. Workers have less exposure to repetitive motion injuries and less exposure to biohazards
  6. Reduce the potential for errors caused by evaporation or contamination
  7. Reduce time spent on tedious manual tasks
    Outstanding Capacity
  8. The DxC 800 delivers stat results faster than almost any other random-access instrument available today
  9. Results for 11 critical care tests are available in 42 seconds
  10. Stat interrupt capability means routine processing doesn’t slow down the turnaround of urgent requests
  11. Choose from a menu that includes more than 100 liquid, ready-to-use reagents
  12. The DxC 800 offers 70 different reagents on board at once
  13. Liquid reagents eliminate time-consuming reagent preparation
  14. Most reagents are packaged with enough volume for hundreds of tests, minimizing operator intervention with the system
  15. If reagents are required, operators can load while the system is running
  16. No need to interrupt workflow to reconfigure on-board menu
    Simplicity in Operation
  17. Calibration processes minimize time-consuming, labor-intensive steps
  18. Calibration data is provided on disk, so technologists don’t have to key in necessary information
  19. Almost all calibrators are liquid and ready-to-use, eliminating reconstitution, clean up, and potential result variability
  20. The systems automatically accept within-range calibrations
  21. The systems require no daily maintenance and minimal weekly maintenance
  22. Automated routines for some maintenance procedures eliminate hands-on time by operators
  23. Proactive alerts for system maintenance let you know in advance when maintenance is due
  24. Onboard maintenance logs with supervisor approval facilitate paperless maintenance records
For questions about using the MedWrench web site:
(866) 989-7057TOLL FREE  •  (770) 692-8371INTERNATIONAL
support@medwrench.com
MedWrench is in association with:
TechNationMedical DealerOR TodayMD Expo
Testimonials  •  Advertising  •  Privacy Policy  •  Terms and Conditions
© 2017 MedWrench, LLC. All Rights Reserved
