Biotechnica - BT 3000 TARGA
by Biotechnica
Automatic analyzer random access for clinical-chemistry computer controlled.
It can perform end-point, kinetic, initial rate, differential, dichromatic, fixed time, latex and sample blank tests. Automatic - upon programmation - pathological results repetition with or without automatic dilution. Automatic - upon programmation - pathological results in the panic range repetition. Urgent tests in actual time (STATs). Sophisticated software for the system control. 32 on line tests mono or double reagent.
FORUMSView All (5)
-Tito17
7 years ago
Code processor or controller Z80
Hello, I would like to know which is the code of de processor or controller Z80 of the Targa BT 3000's movement's plaque. Thank youReply
-Bsoumia
9 years ago
biotecnica targa 3000 et biotecnica falcor 350
bonjour je souhaiterais connaitre la difference entre le biotecnica targa 3000 et biotecnica falcor 350 .merci
-abuashraf1974
10 years ago
ilab 300 software
I am in desperate need for a ilab 300 software as targa bt3000 software with a internal pc Please help abuashraf1974@yahoo.com
Throughput300 samples/hr
Sample Volume1 to 100 µL
Reagent Dispensing Volume1 to 300 µL
[list]  Methods: Kinetic, End Point., Fixed Time, I.R., non linear, sample blank, latex         Test on-line: 40 reagents, single or double         Programmable tests: 160 single or double reagent+ "relation test"         Sample tray: 70 positions: 40 samples + 10 STATs + 16 STD and 4 controls. Primary tubes and/or sample cups  Bar code reader: Positive identification of samples and reagents         Optical system: Colorimetric          Light source: Halogen dichroic lamp 12V - 35W  Incubation temperature: 30 or 37°C ± 0.1°C         Refrigeration temperature: 10-13°C  [/list]
