Ortho Clinical Diagnostics - VITROS 5,1 FS
Clinical Chemistry at another level.Intellicheck Technology, featuring SMART Metering and Save-the-Sample Clot Management, is designed to minimize unnecessary repeats, re-draws and corrected reports – giving you excellent result integrity. MicroSensor Technology provides sample quality indices so you can cost-effectively decrease the amount of time, labor and subjectivity associated with interpretation.
MicroSlide Technology is designed to deliver the highest patient-reportable result efficiency (First Pass Yield)** – reducing non-value-added tasks, while improving morale and staff retention. e-Connectivity Interactive System Management provides real-time access to information for proactive diagnosis and remote repair and puts knowledge at your fingertips – all of which maximizes uptime and increases staff productivity.
Simple By Design – VITROS Systems are self-monitoring, with intelligent system fault recovery. This, along with minimal maintenance, no reagent preparation and up to 6-month calibration stability, means fewer intervention steps and true walkaway operation. MicroTip Technology enables expanded menu offerings of Therapeutic Drugs, Serum Proteins, Drugs of Abuse, user-defined applications and esoteric testing without the cost, maintenance, carryover and contamination risks associated with traditional water-based systems.
A Wide Accessible Menu means the entire test menu is on-board at all times. And with Intelligent Parallel Processing, lower volume esoterics don’t compromise high-volume STAT and routine testing.
FORUMSView All (4)
0Replies9 years ago | MACHINE NOT RUNNING BECAUSE OF CODE 828 WHAT IS WRONG WITH MACHINE,VITROS 250 WHEN IT DEPLAYS CODE 828 AND CAN NOT RUN Reply |
0Replies9 years ago | Urine Drug Screen Could I get a detailed list of the drugs tested in the urine drug screen and how far back are the drugs in the body detected? In other words, how long will a drug be in the body to be detected? Thanks Sandy Reply |
2Replies11 years ago | Operator manual requirement
Can any bocy please provide me operator manual of Vitros 5.1 Reply |
- Intuitive, easy-to-use and easy-to-train graphical user interface
- On-board documentation (VDocs) with animated help
- e-Connectivity Interactive System Management for proactive diagnostics and updates
- 160 samples on board and a dedicated STAT lane
- Disposable tip metering
- Repeat, reflex and dilution testing
- Up to 6-month calibration stability
- True workflow consolidation with 80 tests on board (45 MicroSlide, 35 MicroTip) and 125 Reagent positions
- Single-use disposable electrodes (Direct Potentiometry)
- Parallel processing of routine and special tests for uncompromised workflow
- MicroSensor sample quality indices
- Reagentless, no additional sample volume requirements and no impact on productivity
- 10 user-defined applications
- No water, plumbing, drains, fixed probes or mixing assemblies
Height | 52.5 in |
Sample Capacity | 160 samples in Universal Sample Trays (150 routine samples plus 10 in dedicated STAT lane) |
Length | 92.2 in |
Power Requirements | 200-240 VAC |
Weight | 1400 lbs |
Sample Types | Serum, Plasma, Urine, CSF, Whole Blood |
Sample Volume | 2 to 12 µL |
Width | 33.4 in |
MicroSensor: Scan for sample interferences (hemolysis, icterus, turbidity) over 400-800 nm wavelengths
On-Board Test Capacity: Up to 80 different assays resident onboard simultaneously. 89 MicroSlideTM and 36 MicroTipTM positions
Calibration: Unlimited number of lots may be pre-calibrated
Stability: Up to 6 months
Process: Random access;25 calibrations per assay body fluid combination
User-Defined Channels: 10 available
Data Storage: 25,000 samples, ability to archive and retrieve through CD-ROM
