Ortho Clinical Diagnostics - VITROS 350
by Ortho Clinical Diagnostics
A compact chemistry system designed to be efficient, dependable, and above all, easy to use as a primary, STAT, or backup system.
The VITROS 350 Chemistry System offers easy operation, maintenance, and training. Whether users use it as a primary, STAT, or back-up to the powerful VITROS 5,1 FS, the VITROS 350 Chemistry System will get the job done right the first time. Users know that VITROS Systems are efficient, dependable, and easy-to-use. The VITROS 350 comes complete with enhanced throughput, a broad accessible menu, and new ergonomic design. Boosts productivity and reduce costs with the system that delivers the right results the first time.
FORUMSView All (27)
-Sajid ali048
9 months ago
Urgent
Please tell me how to turn on this machineReply
-Sajid ali048
9 months ago
Vitros 350
Please tell me how to turn on vitros 350Reply
-heshamsamir2000_1312
2 years ago
Urgent
I am user for Machine vitros 350 , could u please send me Manual operation and troubleshooting and Vedios ThanksReply
  • The VITROS 350 doesn’t require highly-trained operators—simple procedures allow around-the-clock availability to all members of the lab staff
  • Easy to train and cross train operators
  • Walk-away operation
  • Quality control procedures are required just once each day and calibration intervals up to 6 months
  • Ergonomically designed, flat low-glare LCD touch screen monitor
  • Keyboard platform and support arm
  • Flexible, customized positioning
  • On-board documentation and help function
  • Up to 300 results per hour
  • On-board capacity for all 45 assays
  • Primary tube sampling
  • On-board dilution
  • Flexible processing for manual, stat or automated testing
  • Unique sample processing capabilities like disposable tips, bubble and clot detection assure confidence in results
  • Self-monitoring alerts operators to prompt action, avoiding testing delays
  • No plumbing, drains, vents, deionized water is required; all “waste” is contained in used test slides which are disposed daily
Sample Capacity40 (4 trays of 10 samples)
Throughput3600 samples/hr
Sample TypesSerum, Plasma, Urine, CSF
Sample Volume5 to 11 µL
    Potentiometric Reaction Time: ~ 2.5 minutes
    Colormetric Reaction Time: ~ 5 minutes
    Immuno-rate Reaction Time: ~ 8 minutes
    Sample Management: Clot Detection, Bubble Detection, Liquid Level-Sensing (Pressure Transducer), Short-Sample Detection
    Calibration: Extended; multiple lots supported
NEWSView All
Device Alert
Problem: In a February 4, 2011, Urgent Field Safety Notice letter posted by the U.K. Medicines and Healthcare Products Regulatory Agency (MHRA), Ortho-Clinical Diagnostics (OCD) states that it has received reports in which users observed increased signal-to-cutoff (S/C) ratios for negative patient and quality control samples when using the above re...
