Ortho Clinical Diagnostics - VITROS DT60 II
Flexible, modular benchtop chemistry system for routine or emergency clinical chemistry testing in a variety of settings, including physician offices.Get all the benefits of VITROS® MicroSlide™ Technology in a size that’s perfect for your laboratory. Fast, more accurate results with an easy-to-use, cost-effective solution. The modular VITROS® DT60 II Chemistry System suits your workflow perfectly. You’ll get the ultimate in flexibility and value with this modular chemistry system. Extensive test menu covers a full range of assays and applications, including basic chemistries, electrolytes, enzymes, full lipid profiles, and derived tests. Provides the convenience and reliability for routine or emergency clinical chemistry testing in many facilities. MicroSlide Technology is designed to provide the highest reagent efficiency in the industry. Overall costs will be more predictable, and you’ll get greater value for your investment. The MicroSlide’s thin layer of microfilm have all the reagents you need to test and filter out interfering substances – functions that are normally associated with larger, more expensive systems, not one designed for the benchtop.
FORUMSView All (4)
3Replies7 years ago | Metabolites measuring I would like to know the entire analysis I could perform with this equipment Thanks in advance akrimer@gmail.comReply |
2Replies12 years ago | VITROS DT DONDE PUEDO ENCONTRAR PARTES PARA EL VITROS DT60 Y DTSC Reply |
1Reply12 years ago | DTSC II What is the full meaning of DTSC Reply |
[list] [*] Advanced Security - Dry slides filter interferences, generating accurate, worry-free results. Additionally, by using direct ISE slides, you can be confident that there’s virtually no chance of pseudohyponatremia or any maintenance of electrodes. [*] Labor Optimization - Free your staff for more value-added tasks with a system that’s simple to use and requires no reagent mixing, minimal maintenance, and calibration only when you change reagent lots. [*] Enhanced Service Levels - Get consistently accurate results in two to five minutes. Random access testing lets you run chemistries in any order you choose. The small sample size is especially helpful for pediatric, geriatric, and hard-to-test patients. With all three modules, you can run up to 100 tests per hour. [*] Cost Containment - Save time and make more efficient use of consumables. There’s minimal waste, no plumbing, and nominal storage requirements. [/list]
Height | 17.1 cm |
Length | 34.9 cm |
Weight | 8.6 kg |
Width | 47.6 cm |
