Ortho Clinical Diagnostics - VITROS ECiQ
A powerful immunoassay system for routine and specialty testing designed for low- to mid-volume laboratories that require continuous processing.The VITROS ECiQ Immunodiagnostic System is the best solution for laboratories performing routine and specialty immunodiagnostic testing. Thanks to proven VITROS Technologies, including our proprietary INTELLICHECK Technology, this system is designed to give the highest level of confidence in quality result reporting by verifying and documenting steps throughout processing. All of which equals greater confidence reporting these results while making the laboratory more efficient and users' lives simpler.
FORUMSView All (5)
0Replies3 years ago | Service Manual I'd need the service manual, troubleshooting a problem, the RTPs don't report voltage, no communication between the main CPU and the boards. It boots with SW 3.9, energizes as well, but the instrument wont come up. Reply |
0Replies3 years ago | Software load issue Trying to load SW 3.9 won't load RTP error message 99 comes up. Reply |
0Replies5 years ago | service manual i need service manual eciq Reply |
ADVANCED PROCESSING CENTER
- Ensures result integrity for quality result reporting
- Patient samples and reagents automatically metered into MicroWells
- INTELLICHECK Technology verification at each step
- Dual-logic processing optimizes assay performance and throughput
REAGENT MANAGEMENT CENTER
- Optimizes labor by reducing operator intervention
- Up to 20 Integrated Reagent Packs loaded any time and stored on-board for continuous, random access operation
- Automatic Inventory Management monitors and verifies inventory, expiration, and calibration
- INTELLICHECK Technology verifies MicroWell dispense and assay reagent aspiration and dispense
SAMPLING CENTER
- Reduces errors for worry-free result reporting
- Unique Save-the-Sample Clot/Bubble Detection preserves the specimen and minimizes redraw
- Disposable Tip Sample Metering verifies sample aspiration and dispense, while addressing carryover and cross-contamination concerns
- Universal Sample Trays accommodate primary, secondary, and microcollection containers and sample cups without adapters or pour-off containers
e-CONNECTIVITY CENTER
- Maximizes system uptime and increases staff productivity
- Highly secure, real-time two-way communication between your system and our support teams
- Automatic Data Exchange and Remote Connectivity for immediate diagnostic and performance analysis
- Immediate resolution of technical issues without a service visit
Measurement Principle: Enhanced Chemiluminescence MicroWell Technology: Excellent assay sensitivity and precision, small sample volumes and minimal waste Reagents: No preparation; no mixing and reconstitution required for Integrated Reagent Packs, Signal Reagent and Universal Wash Reagent On-Board Test Capacity: • Up to 2000 assays • Up to 20 different Integrated Reagent Packs • 100 assays each • Resident on-board simultaneously • Automatic, self-contained, temperature and humidity controlled Reagent Supply Calibration: Multiple lots may be pre-calibrated with automatic lot switching • Up to 28 days • Process: Random Access Calibration with Automatic Result Protection; 25 calibrations across 16 lots per assay System Startup: Automatic Integrated Prime/Purge • No primes, purges, washes or tubing maintenance • No daily calibrations or calibration checks Throughput: Up to 90 reportable patient results per hour Sample Types: Serum, Plasma, Urine, Amniotic Fluid*, Whole Blood** Sample Volume: 10-80µL Sample Capacity: 60 samples in Universal Sample Trays Sample Containers: Universal Sample Trays accommodate: • 10mL, 7mL, 5mL collection tubes • 1.5mL micro-collection containers • VITROS Microsample cups and 0.5mL and 2.0mL cups
