Schiller - CARDIOVIT AT-10 plus
by Schiller
The CARDIOVIT AT-10 plus is designed for high volume ECG environments
The CARDIOVIT AT-10 plus is designed for high volume ECG environments, so that the unit can be used wherever ECG and spirometry data must meet highest demands. Its legendary predecessor, the CARDIOVIT AT-10 is used in many clinics and practices and even in the international space station ISS and its control centres.
FORUMSView All (6)
-Giannipg
2 years ago
No boot...
AT POWER ON THERE ARE THREE BIP AND THEN DISPLAY WHITE... WHAT MAY BE THE PROBLEM? THANKS IN ADVANCE. Giovanni
Equipment: Schiller - CARDIOVIT AT-10 plus
-LeonardoZimolo
3 years ago
Ecg Artifact
Good morning, I have a problem with artifacts on the ecg trace. We have tried to replace the patient cable, adapters, electrodes and to work on battery, excluding problems from the electrical network. The patient is regularly shaved and properly prepared before the application of the electrodes but I continue to have the trace, especially with the peripheral leads, which oscillates with respect to the baseline. I also opened the tool to clean the contacts and found no anomalies. I enclose some examples in the hope that someone can give me some suggestions to solve the anomaly. https://ibb.co/TrnZ3n5 https://ibb.co/djdXf0S https://ibb.co/tLbw7NS https://ibb.co/9brTpL6 Reply
-vgam_8452
4 years ago
Schiller AT10 ECG
Does anyone know how to change the language of this machine. The AT10 plus seems to be easy but my German is not sufficient to use this machineReply
[list]     [*] Compact laptop design     [*] Single button operation for printing, storage and transmission     [*] 12/16 channel resting and exercise ECG     [*] High-resolution 10.4" TFT colour display      [*] Built-in thermal printer with A4 printing paper     [*] Worklist (for auto-download of patient demographic data from the ECG Management Systems)     [*] Ethernet networking     [*] WLAN (optional)      [*] Risk stratification tools such as Thrombolysis, HRV and Signal Averaged ECG (SAECG)     [*] Barcode scanner, to reduce misspellings     [*] Internal memory for up to 350 ECG recordings     [*] Rechargeable battery for mobile use     [/list]
EKG/ECG TypeRest
