Schiller - CARDIOVIT AT-102
by Schiller
Get high performance without spending a fortune.
The CARDIOVIT AT-102 has it all! The most important Cardiopulmonary Function Tests are combined in one single device:   [list]  [*] Resting ECG    [*] Exercise ECG    [*] Spirometry  [/list]
FORUMSView All (5)
-Eng.sadeq
7 years ago
problem
we have this massage when printed refill pepperReply
-fatimaA
8 years ago
no printing lines
-Ray Brown, CBET
9 years ago
Spirometery and ECG on the same patient
Greetings. We have a question from one of our clinics that uses this machine. They complain that after they do a spirometry test on a patient, when they want to do an ECG on the same patient, they have to reload all of the patient information in it. We don't have the operator manual here, and I can't seem to find an electronic copy anywhere, so is there an easy solution to this? Could it be that they need to do the ECG first and then spirometry? Any ideas or suggestions? Thanks!
           Ray
[list]  Resting ECG   [*] Integrated 3-channel monitor   [*] Alphanumeric keyboard   [*] Direct keys for the most important functions   [*] Easy Print: Integrated high-resolution A4 thermal printer, subsequent print-out on thermoreactive paper possible   [*] Interface for external printer for A4 printouts on regular paper   [*] Internal memory for up to 40 records   [*] Interface for data-transmission      Exercise ECG   [*] RS-232 port for peripheral devices such as treadmills, bicycles etc.   [*] For exercise ECG, several standard protocols are available for bicycle and treadmill ergometers; the user can either select a standard protocol from a table or define a new protocol   [*] J-point settings: J+20,+40,+60,+80 ms; default: +60 ms   [*] Blood pressure (Blood pressure measurement: Automatic if a bicycle contains an interface for the blood pressure transfer or manual)   [*] 10-sec. printout: A 10-sec. printout can be initiated at any time on the internal thermal printer      Spirometry    [*] Unique disposable sensor SP-250 minimizes the risk of contamination   [*] SP-260 with reusable sensor   [*] Simple and fast calibration   [*] Memory for up to 40 records   [*] Inspiratory and exspiratory tests; pre and post medication tests   - Selectable predicted value tables   - Real-time curves and measurement information on the large screen   [/list]
EKG/ECG TypeRest
