Sorin Group - 3T Heater-Cooler System
by Sorin Group
The Stöckert Heater-Cooler System 3T provides fast and efficient heating and cooling, independent of the ice and water supply in the operating room.
Three water tanks provide separate settings for warm cardioplegia, cold cardioplegia and patient temperature. Patient temperature settings can be adjusted to the tenth decimal point for accurate temperature control. Furthermore, water in the lines can be pulled back into the tanks at the end of the case to facilitate cleanup.
1Replya year ago | Error EE23 Dear sir this error mean an problem by the pump ...i replaced the pump with the same part but the problem is ...new pump hase tow wire ...old one hase 3 wire ...how i can solve this problem please Reply |
2Replies3 years ago | No power My unit will not start up. The fuse on the power distribution board is in tact. Where else should I look?Reply |
1Reply4 years ago | What is errorEE4 What is error. Code EE4Reply |
Height | 33.2 in |
Length | 26.8 in |
Weight | 228.5 lbs |
Width | 19.8 in |
The FDA is providing new information about Mycobacterium chimaera (M. chimaera) infections associated with the use of the 3T in patients who have undergone cardiothoracic surgeries.
