Roche - Cobas Integra 400 plus
by Roche
Clinical Chemistry Analyzer
With the COBAS INTEGRA 400 plus, innovation means 4 on-board measurement technologies, robotic handling of reaction cuvettes and improved operator ergonomics. This supports the very broad menu and ease-of-use required for true workload consolidation, leading to efficiency gains only possible with only one analytical platform, one user interface, one reagent system and the one global supplier - Roche
Sample selective bench top analyser for small to mid-size laboratories. Flexible system for consolidating routine workload with a capacity of 36 tests (including 4 ISE: Na+, K+, Li+, Cl-) on board and a throughput up to 400 test per hour.
0RepliesFri Dec 05 2025 | End of Sale / End of Support Hello - does anyone know when Roche might stop selling and / or supporting the Cobas Integra 400 Plus? I have a unit that needs fixing and need to figure out if it's worth it. Thank you. Reply |
2RepliesTue Oct 31 2023 | Roche/Hitachi Cobas Integra 400+ service manual wanted Hello colleagues, please advice on Cobas Intergra 400+ if someone has last version( 2019 and up) of service manual with schemas & diagrams? Waiting for your reply in private messages. Equipment: Roche Cobas Integra 400+ Reply |
1ReplyTue Oct 10 2023 | hardware problem detected in the fluid controller I got an error message about a hardware problem detected in the fluid controller with the message ID 14.3235.05.011.019. Do anyone know what's happened and how to fix it? Reply |
| Height | 75 cm |
| Throughput | 400 tests/hour |
| Wavelength Range | 340 to 800 nm |
| Length | 66 cm |
| Weight | 230 kg |
| Sample Volume | 2 to 50 µL |
| Measuring Range | 0 to 2 |
| Width | 135 cm |
