Siemens - ADVIA 2400
by Siemens
The ADVIA 2400 Chemistry System pushes your laboratory’s productivity levels while maintaining the reliability and stability that keep users up and running.
A rapid 2-second probe cycle time maximizes tube speed and test throughput, and combined with the system’s efficient automation-readiness, gives users the turnaround time your high-volume laboratory needs.
FORUMSView All (3)
-Dr. Hugo Romeu
Sat May 03 2014
reagents
is there any where else to buy reagents, rather than deal with siemens
-lisa chitawuro
Mon Aug 12 2013
maintenance
i would like more information on advia 2400 maintenance
lisa
-karthikeyan.ar
Fri Jan 28 2011
measurement point change
Measurement point change possiblities , by manually or by the machine itselfReply
  • Up to 2400 tests/hour (1800 photometric and 600 ISE)
  • Rapid, consistent 2-second cycle time
  • Top-of-class throughput of 200 tubes per hour when running ISEs and up to 9 photometric tests
  • Automatic Sample Retain technology, auto-repeat, auto-dilution and auto-reflex testing
  • Point-in-space aspiration offers connectivity to track or rack handler without robotics or special hardware
  • Redundant sample loading for built-in backup and easy handling of non-routine samples
  • Direct sampling from track prevents detaining tubes at analyzer and reduces aliquotint
  • Minimal-maintenance ISE
  • No-maintenance 37oC incubation fluorocarbon bath oil
  • Auto-calibration and auto-QC from refrigerated on board calibrator and controls
  • Microvolume technology with 32,000 tests onboard and up to 60 days onboard stability maximizes walkaway time
  • Sample integrity check for icterus, hemolysis and lipemia
  • Sample probe with automatic clot/clog detection, liquid level sensing, short sample detection and crash protection
  • Advances in reagent onboard stability, calibration frequency, interference reduction and linearity expansion
Height52.8 in
Length 34.1 in
Power Requirements100-240 VAC
Weight1389 lbs
Width67.4 in
