Advertisement
Siemens - Dimension RxL Max System
Manufactured by Siemens
Dimension RxL Max Integrated Chemistry System
The Dimension RxL Max Integrated Chemistry System, the embodiment of Siemens commitment to provide innovative solutions that improve processes in the laboratory.
The Dimension RxL Max System is founded on the belief that a product born of sound, purposeful design and forward thinking does not need to entirely change, but intelligently evolve and continually improve.
Engineered for maximum performance, the Dimension RxL Max System remains true to the original concept while elevating performance to new heights. The result — the most powerful and technologically advanced Dimension Analyzer yet, and the new standard for excellence in clinical diagnostics. Simply put, the best — maxed.
QUESTIONS & ANSWERSView All
Answers
-SAziz
a year ago
ISE
Reagent volume consumption for each tests for Na/K/CLReply
Answers
-Sarisa
a year ago
How many test run when autocalibrate of IMT
I found the reagent loss too much when RXL start to IMT calibrationReply
3
Answers
-trurman
2 years ago
is it recommended to doing ABS
we are working now in libya without ABS Reply
DOCUMENTS / MANUALS
PREVENTIVE MAINTENANCEView All
Answer
-Dr Kumar
2 years ago
frequency of preventive maintenance
We are using Siemens Dimension Instruments (EXL, RXL MAX and expand) in our lab for routine chemistry. The PPM frequency used to be 4 times a year. recently they made it semiannual. What is the ideal frequency of PPM (number of times PPM should be done in a year) for dimension chemistry analyzers. we use the analyzers24x7x365 Dr. Kumar Saudi ArabiaReply
  1. Fully automated and integrated testing of over 80 methods
  2. Unprecedented 91 methods on-board concurrently
  3. Higher throughput with expanded reagent capacity for larger workloads
  4. Reagent Management System (RMS) module enables
    - Double reagent capacity
    - Ability to load up to 18 Flex® Reagent Cartridges at one time
    - Separate reagent preparation probe improves instrument efficiency
  5. More results from one tube on one platform
  6. Actual throughput to handle peak workload
  7. Highly responsive
    - Run any test, at any time on any sample type
  8. Auto-calibration of electrolytes (NA, K, CL)
  9. Truly integrated processing of chemistry with uncompromised throughput
  10. Single Station, Multi-Tasking Workstation Connectivity
  11. Connectivity to Siemens automation systems through Sample Transfer Module (STM)
Height68.2 in with monitor
Length 32.3 in
Weight880 lbs
Width62.5 in
NEWSView All
!{article.title}
Siemens Announces FDA Clearance of ACUSON SC2000 Prime Ultrasound...
Siemens Announces FDA Clearance of ACUSON SC2000 Prime Ultrasound System
!{article.title}
Siemens Multix Fusion Digital Radiography System Now Commercially...
Digital imaging solution offers state-of-the-art X-ray technology for smaller budgets.
!{article.title}
Siemens Announces Publication of Research Data Identifying Potential...
Study findings suggests potential use of [18F]-T808 as PET imaging agent for tau protein pathologies associated with Alzheimer’s disease
Advertisement
Ask anything about
Advertisement
For questions about using the MedWrench web site:
(866) 989-7057TOLL FREE  •  (770) 692-8371INTERNATIONAL
support@medwrench.com
MedWrench is in association with:
TechNationMedical DealerOR TodayMD Expo
Testimonials  •  Advertising  •  Privacy Policy  •  Terms and Conditions
© 2017 MedWrench, LLC. All Rights Reserved
Advertisement
