Thermo Scientific - Konelab 20XT
Compact clinical chemistry analyzer for routine and special testing in smaller laboratories.The Konelab 20XT analyzer is a random access clinical chemistry system for routine and special chemistries, including specific proteins, electrolytes, therapeutic drugs and drugs of abuse tests. The Konelab 20XT analyzer has a small footprint and do not require any external water supply or drainage. Various automated features save time in sample processing. The Konelab 20XT analyzer is designed to meet the needs of medium and small routine and specialty clinical laboratories. The unique low-volume cuvette design ensures error free operation and minimum reagent consumption.
FORUMSView All (6)
0Replies2 years ago | Konelab 6.5 Software Where can I get a copy of the Konelab 6.5 software to reinstall?Reply |
0Replies9 years ago | intervention sur les konélabes 20i et 20 XT 1) Quelles sont les précautions à prendres avant toutes intervention sur les Konélabes 20i et 20XT? 2) est ce qu'il y a un manuel d'ajustement de ces konélabes en français? il sera un un reconaissable service si vous m'envoyez sutout le manuel d'ajustement en format PDF. Reply |
0Replies9 years ago | maintenance préventive Qu'elle est le plan de la maintenace préventives adéquat pour les konélabes 20xt et 20i ?
Reply |
[list] [*] Throughput up to 250 tests per hour [*] 84 sample positions with continuous loading segments [*] 5 STAT positions [*] 35 reagent positions, real-time reagent status seen [*] 50 cuvettes on-board, 2.5 hours walk-away time [*] Konelab 20XT uses clear and easy-to-navigate graphical user interface providing fast guidance and easy access to all functions. The user interface is available with several languages. [/list]
Height | 115 cm |
Sample Capacity | 14 Positions |
Throughput | 250 samples/hr |
Length | 79 cm |
Weight | 142 kg |
Measuring Range | 340 to 800 nm |
Reaction Method | Colormetric-rate |
Width | 80 cm |
[list] Dilutions: Automatic sample pre-dilution. Automatic post-dilution with both high and low secondary dilution ratios. Possibility to add the value of manual pre-dilution for the result calculation. Reaction incubation: For 6 multicell cuvettes (i.e. 72 reaction cells) [/list]
