TRANSASIA - ERBA XL-600
Automated random access clinical chemistry analyzer.The Erba XL 600 is a fully automated, random access clinical chemistry analyzer with throughput of 600 tests/hr with I.S.E (Na/K/Cl). This economical analyser is designed to give you quick returns without any compromise. The high resolution diffraction grating ensures a very high degree of photometric accuracy.
1Reply10 years ago | cycle time can anyone help me to understand the cycle timing for XL600 and XL640 instrument, or provide me user maual for the same Reply |
- Bar coded reagents and sample identification minimizes programming time
- Sapphire oump for improved precision and accuracy
- Permanent hard glass cuvettes
- Offers a wide choice of 50 different on-board tests
- Cooled reagent tray to hold 50 bar coded bottles
- Specially designed “Twin layered” sample disk
- Probes with Vertical Obstruction Detection facility
- Primary tubes sampling with bar coding
- Capability to perform 2 reagent tests
- Economical 200 µl reagent consumption / test
- Low D.I water consumption
Height | 1100 mm |
Throughput | 600 samples/hr with ISE |
Length | 610 mm |
Power Requirements | 110/220 VAC |
Weight | 150 kg |
Sample Volume | 20 to 60 µL |
Reagent Dispensing Volume | 10 to 300 µL |
Width | 840 mm |
