UDI - RASTAT
by UDI
RASTAT is a fully automatic random access, continues loading, easy access bench top Clinical Chemistry and Immunoturbidimetric analyzer.
The instrument features primary tubes sampling, capacitive liquid level sensing, positive identification of the samples (optional), and module for ISE (optional). It is therefore suitable to perform the daily routine of low/medium - sized laboratories in a entirely safe and reliable way, providing flexible and cost effective solutions. The RASTAT multitasking and user friendly software, running under Windows 98, enhances the system's potential and performance
[list]    [*] Easy to follow with user guidance on screen.     [*] Monitoring of reaction curve for patient samples.     [*] Monitoring of reagent volume by computer.     [*] Data transfer to host computer.     [*] Test via standard or via factor.     [*] Extensive quality control.     [*] Graphical display of QC results.     [*] Patient entry during operation.     [*] Programmable automatic wash between samples and test runs.     [*] Comprehensive error code handling.    [/list]
Throughput333 samples/hr with ISE (200 without ISE)
Optical SystemPhotometer: multi - wavelength dual channel optic
Light Sourcehalogen lamp 6V/10W
[list]  ASSAY TYPE: End point, Kinetic, Differential, Bichromatic and Immunoturbidimetric; up to 999 tests, all user programmable.      ON LINE REAGENTS:     4 racks are provided to hold up to 33 reagents that are divided as follows:      - 2 racks cooled by Peltier cells holding up to 20 reagents     - 2 racks for 13 reagent positions and 14 standards and controls at room temperature  - 2 additional positions for diluents.     SAMPLES LOADING:     5 racks for continuous loading of samples split in:     - 64 positions for routine samples     - 14 positions for STAT samples     PRIMARY TUBES SIZE:     max 16 mm x 100 mm (height)     READING SYSTEM: Direct photometry     MINIMUM REACTION VOLUME: 300 µl   [/list]
