UDI - UDICHEM-310
by UDI
Semi-Automated Clinical Chemistry Analyzer UDI UDICHEM-310
FORUMSView All (3)
-Wadbadi
a year ago
Udichem 310 chemistry analyzer
Hello everybody, please I need Operating manual for Udichem 310 chemistry analyzer
-antar
12 years ago
filter problem
HI , i want to ask about the results  that u add already the cholesterol ( udi) reagent to device on filter 505 and the results always give high although  we make control and standerd ?
-Khaledmarz
13 years ago
Udichem 310
Hi there, I am Dr. Khaled Marzouk, Clinical Pathologist. I have a problem with my device (udichem 310), the card of the photocell is out of order. My local supplier didnt have this spare part in Egypt. Please tell my how can I solve this  problem, and where is the nearest supplier and his address and e-mail. Thank you, can I buy it through the net ?.
[list]      [*] Easy to be used as simple spectrophotometer as well as semi-automated analyzer  [*] 75 programmable channels open and ready to be programmed for different tests  [*] Programming for laboratory identities, units, filter positions and printer control  [*] Curettes (micro, macro and semi-micro) and tubes (12mm) both can be used  [*] 9 Filters are totally in the system (340,405,420,450,505,546,578,630 and 670 nm)  [*] Flow system with peristaltic pump included in the housing with pump stepper motor controlled in low voltage  [*] Thermostatic control with Pettier effect from 23°c to 40°c increasing 1°c each time  [*] Bench top model with 60-tests/hour capacities  [*] Open system with 75 programmable locations for Chemistry, Immunology, TADS and Electrolytes  [*] Free maintenance unit  [/list]
Light SourceHalogen lamp 12V/20W
