UDI - Udichem UDILIPSE
by UDI
The only unit dedicated to run G6PDH test for haematology needs.
Fully automatic - random access, continuous loading, bench - top analyzer for Clinical Chemistry and Immuno turbidimetric assays.
[list]      [*] Easy to follow with user guidance on screen.       [*] Monitoring of reaction curve for patient samples.       [*] Monitoring of reagent volume by computer.       [*] Data transfer to host computer.       [*] Test with one ,two or three reagents.       [*] Test via standard or via factor.       [*] Extensive quality control.       [*] Graphical display of QC results.       [*] Patient entry during operation.       [*] Programmable automatic wash between samples and test runs.       [*] Comprehensive error code handling.      [/list]
Height525 mm
Throughput130 samples/hr WITHOUT ISE
Length 750 mm
Weight43 kg
Optical SystemPhotometer: direct photometry, double beams, multi - wavelength optic
Light Sourcehalogen lamp 6V / 10W
Sample Volume2 to 50 ml
Reagent Dispensing Volume25 to 400 ml
Width570 mm
[list]  Assay Types: End Point, Kinetic, Differential, Bichromatic and Immunoturbidimetric. Up to 200 different tests, all user programmable  Test Entry Modes: selective - profiles - batch - STAT  Samples Loading: 4 separate sectors with 8 positions each for continuous loading of samples  Minimum Reaction Volume: 200 ml  Optical Path: 6 mm  Linear Range: 0.0005 ¸ 2.500 Abs  [/list]
