Biochemical Systems - Clin Check Plus
Analyser for basic clinical chemestry.Clin Check Plus is an interferential filter photometer, designed for a precise and fast execution of the most important tests of Clinical Chemistry and Hematology. The execution of the analyses and programming the instrument are simple and guided by the instructions shown on the display. It is possible to select a language among German, Italian, French, English. The light source of Clin Check Plus is a 2 W tungsten lamp: this enables the instrument to read in the UV range too. 5 interferential filters are incorporated: the proper wavelength of the Test is automatically selected by microprocessors. Iit is possible to add a sixth filter, upon request. The instrument has a 2-position Dry Block Incubator at 37° C ; the Reading compartment is also at 37° C to ensure a constant temperature during the Reaction Time. The thermostat turns on automatically when the instrument is switched on.
0Replies6 months ago | Clincheck plus analyzer key pad i need key pad for clincheck plus analyzer Reply |
0Replies10 years ago | hello my dear i wona help
error: out of range Reply |
[list] [*] Laboratory photometer, completely Programmable up to 40 tests which can be recalled by keyboard at any time. [*] 6 interferential filters. [*] 2 positions 37ºC incubator. [*] The open system makes it possible to use either single cuvettes with prefilled reagent or traditional reagents in flasks. [*] Printer and computer output by RS232 [/list]
Height | 9 cm |
Length | 21 cm |
Weight | 3.8 kg |
Width | 27.5 cm |
[list] Spectral range: 320-750 nm Filter Wavelenghts: 340-405-505-546-578-630 nm interferential filters Operating modes: Absorbance, End Point, Fixed-Time, Kinetic and Multistandard Measuring range: from -0.200 to +2.000 O.D. Incubator: 2 positions at 37 °C; ± 0.2°C [/list]
