Biochemical Systems - Clin Check Alpha
by Biochemical Systems
Analyser for basic clinical chemistry
Portable photometer with rechargeable batteries which can perform 6 tests on capillary or venous blood. Number 14 additional channel (OPEN) can be selected using the arrow keys for absorbance measurements 505 nm. The K-Factor can be modified in all channels to insert a new test to be carried out on serum or whole blood. The reagents are already pre-filled in single cuvettes; you only have to collect a drop of blood in a glass capillary (already included in the kit), insert the capillary in the pre-filled cuvette and proceed.                          The results are shown on the alphanumeric display, directly in the measuring units you prefer. The instrument can store up last 30 test results. K-factor modification and Battery/Lamp Check can be easily done from the keyboard. It is possible to connect the instrument to an external computer or a printer through a serial port.
[list]            [*] Portable photometer, with rechargeable batteries and interferential filter at 505 nm, programmable for 20 tests    [*] Open system. Operates on a drop of capillary or venous blood and serum samples    [*] It is possible to connect the instrument to an external printer or computer for storage and trasfer of data through on the RS232 output    [*] Complete with case, autolet device, lancets and capillary holder. Last 30 result are stored in non-volatile memory and can be recalled through PC or external printer    [/list]
Height3.5 cm
Length 19.5 cm
Weight450 g
Width12.5 cm
[list]      Wavelength: 505 nm (single interferential filter)      Test programs: 20 tests (6 installed + 14 OPEN)      Results memory: 30 test results      [/list]
