Hospitex Diagnostics - Screen Master
Powerful features in compact unit for biochemical investigations, enzymes, immunoturbidimetrics and drugs.FORUMSView All (4)
0Replies2 years ago | Screen master touch Hello , i made a password on the scrren touch , i can not remember ,,can you help me to cancel the password to log in?thanksReply |
1Reply6 years ago | manque de mode utulisation screen master plus programmation de la machineReply |
1Reply8 years ago | how to set code for test A new panel was changed and the tests are not encoded Reply |
[list] [*] Integrated pump and flow through cuvette; [*] Internal peltier element pre-sdjusted at 25°C, 30°C and 37°C [*] 8 positions, 37°C incubation block, built-in; [*] Easy to use with step-by-step procedure; [*] Performs End-point, Kinetics, Fixed-time, Multistandards assay; results on graphic printer on board; [*] More than 200 programmable test; [*] Multi-language capability. [/list]
Height | 34 cm |
Length | 33 cm |
Power Requirements | 110/220 VAC |
Weight | 8.5 kg |
Optical System | 6 interferential filters: 340, 405, 505, 546, 578, 640 nm + 2 free filter positions |
Width | 18 cm |
[list] Photometric Range: 0 - 2.5 O.D. Cuvette System: Microflow cell: 32 µL, 10 mm light path interchangeable Against microflow cell with 80 mL, standard cuvettes (macro or semi-macro, disposable or special optical glass) Reaction Volume: 500 µL per test [/list]
