Hospitex Diagnostics - Mini Screen p
Powerful features in compact unit for biochemical investigations.FORUMSView All (4)
1Reply5 years ago | Lampe Caracteristique I would liké to know thé Caractéristique of thé lampe ? Is it 12v 20watt. ? Reply |
0Replies8 years ago | lamp i need to change the lamp can i use lamp 12 v 50 watt Reply |
0Replies10 years ago | Reading error Reply |
- Mini-Screen is a compact, easy to use and reliable system for clinical chemistry analyses.
- The instrument stores up to 50 different test programs which can be recalled by keyboard at any time.
- Equipped with built-in 2 positions thermostat at 37°C and serial RS232 output for printer and computer, MINI-Screen has been designed to perform all basic clinical chemistry and some hematology tests.
- The open system makes it possible to use either single cuvettes with pre-filled reagent for rapid and practical performance or traditional reagents in flasks for laboratory routine.
- Five interferential filters (340-405-505-546-630 nm) assure reliable and repeatable measurements.
- Calculation is performed automatically so that results are displayed directly in the required measuring unit.
Height | 23 cm |
Wavelength Range | 340 to 700 nm |
Length | 29 cm |
Power Requirements | 220 VAC |
Weight | 4 kg |
Width | 23 cm |
Operation Modes: absorbance, concentration, kinetic, fixed time and end point
Bandpass: less than 8 nm
Reprodcubilibty: 1 digit
Temperature: 37°C 0.2 °C
Cuvette Incubator: 2 position
Storage Capacity: 50 test programs
