Pointe Scientific - 180-PLUS
by Pointe Scientific
It is easy to use and is virtually maintenance free so it is a perfect fit for the small laboratory. It offers a comprehensive 48 test pre-programmed menu. Special cuvettes are not needed - tests are performed and read in borosilicate glass test tubes. The Pointe 180 is a small, semi-automated chemistry analyzer with six filters and a surprisingly large test menu. It has an onboard incubator with 12 wells at 37° C, a temperature controlled cuvette well, and internal temperature control. The analyzer leads the user through test performance in a step-by-step manner. The new graphics software allows extended timed absorbance interval data and kinetic data plots to be printed. The analyzer has 48 programmed and 21 open channels, and reads, calculates, and prints results in less than three seconds. The analyzer reads test tubes upon insertion----no need to press a button. Optimized parameters for Pointe Scientific reagents are already entered - just select the test number. The open channels are available for programming other tests. The normal range for each test is automatically printed out, and results that are out of the normal range are flagged. Normal ranges can be edited to fit the area or population. Results generated by the Pointe 180 are comparable to results reported out by hospital and reference labs. The analyzer can use single point calibration by standard/factor, multi-point calibration with point to point curve fit, percent absorbance and rate by standard or factor. These calculation options allow the analyzer to perform endpoint, initial rate, kinetic rate and batch kinetic methodologies.
2Replies13 years ago | user manual i have one unite point spectrophotometer and i need the user manual to know how i can use it can you send it to me at abdullah_amt@yahoo.com Reply |
[list] [*] BICHROMATIC PHOTOMETER SYSTEM - Differential wavelengths to correct for test tube imperfections and to help remove interfering substances. [*] ON-BOARD INCUBATOR - 12 wells at 37° C. [*] TEMPERATURE CONTROLLED CUVETTE WELL - Constant 37° C. This feature is necessary for performing kinetic assays. [*] INTERNAL TEMPERATURE CONTROL - The analyzer monitors the incubator and cuvette well temperatures. The temperatures are automatically corrected and the actual temperature in degrees (°C) is displayed on the screen. [*] LAMP SAVING FEATURE - The instrument automatically shuts off the lamp if the instrument has not been used for 15 minutes. This feature can preserve the lamp for up to two (2) years, depending on actual usage. [*] MAINTENANCE FREE - The instrument does not require any scheduled maintenance procedures. [*] SELF-PROMOTING OPERATION - The analyzer leads the user through test performance in a step-by-step manner. [*] TEST TUBE ACTIVATED READING - The analyzer reads test tubes upon insertion-no need to press a button. [*] FAST READOUT - The analyzer reads, calculates and prints results in under three (3) seconds. [*] PREPROGRAMMED CHEMISTRY PROCEDURES - Optimized parameters for Pointe Scientific reagents are already entered-just select the test number. Open channels are available for programming other tests. [*] PREPROGRAMMED DATA REDUCTION - Calculation programs for cardiac risk factors, Glycohemoglobins and Iron/TIBC are part of the general test menu. [*] PREPROGRAMMED NORMAL RANGES - The analyzer prints the normal ranges and can be edited to fit the area or population. [*] PREPROGRAMMED FLAGS - The analyzer will flag results that are out of the normal range or exceed the linear limits of the analyzer or reagents. [*] AUTOMATIC WAVELENGTH SELECTOR - The analyzer automatically positions the preselected filters for each test. The inclusion of the 340nm filter enables the analyzer to perform assays in the ultra-violet (UV) mode, which is the preferred mode for enzyme/kinetic, assays. [/list]
Height | 10 cm |
Length | 34 cm |
Width | 24 cm |
[list] Linear measurement range: 0.00 to 2.50 Absorbance Units (A) Stability: drift of no more than 0.005A in 8 hours/bichromatic Wavelengths: 340, 380, 405, 490, 550, 600nm Typical half bandpass: 10nm Tube size: 12mm round standard Display: alphanumeric, 16 character, red, LED [/list]
