Schick - accuDexa
by Schick
The accuDEXA Bone Mineral Density (BMD) Assessment System provides a quick, convenient and economical measure for determining a patient's fracture risk. Though small in size, accuDEXA is packed with sophisticated technology. Everything you need to quickly and confidently assess your patient's BMD is housed within the unit. The simple test can be performed right in your office and does not require the removal of garments or the application of messy gels or creams. Results are achieved utilizing super-accurate Dual X-ray Absorptiometry (DEXA), the industry standard for BMD. Simply place the patient's hand in the unit, follow a simple set of commands on the view screen, and in 30 seconds you have the results you need.
3RepliesInvalid Date | The device does not turn on. Hi everyone, once i turn the key, the on/off indicator does not illuminate and the device does not turn on. do you know how to solve it? does anyone have the technical manual? Thank you.Reply |
1ReplyInvalid Date | Repair AccuDexa 7100 I have a AccuDexa 7100 but the equipment didn´t pass the self test, display fail sensor test ..."error # 141 . Please reply as soon as possible the method of solution repair this problem . Do you send for me the shematic of AccuDexa 7100 ! Reply |
0RepliesInvalid Date | Schick Acudexa 7100 Hi, I have the Schick Acudexa 7100. It stopped working years ago when I didn't obtain the software warranty and the chip expired. Can anyone tell me how to get it to work again? When I called Schick years ago, they told me that it just needed to be reset. Thanks, Marcia Sasso Reply |
| Height | 14 in |
| Length | 14 in |
| Swing Away C-arm Capability | Portable |
| Bone Density Imaging Mode | DEXA |
| Width | 15 in |
Weight: 66 lbs (29.7 kg)
